Posted by pete 23 on April 18, 2014 at 10:28:46 from (74.33.94.238):
In Reply to: 1486 reverse problem posted by big1486 on April 17, 2014 at 15:56:47:
I see no one has responded to your problem. Here is what is going on. The shift collar on reverse is going too far and slides up on the splines of driven gear so far it comes disengaged from driving gear. Usually caused by worn or broken fork, or key way in reverse shift lever shaft. May also be caused by too much end play in the reverse shaft assembly. Some times the washers between the gears break, wear out or wear into the rear housing. One other thing is wrong gasket installed between speed transmission and range transmission allowing shaft to move forward a little. Need to take off side fuel tank to remove side cover to take a look. Then run over that tank so you can't put it back on and save everyone who ever has to do any work on the tractor a lot of headaches.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
