Several possibilities: The material of the gasket could be inferior or too thick. The pressure relief in the system could be stuck or sticking. The surface of the block or flange could be distorted. The block to flange bolts could be improperly tightened/partially stripped.
If the system loads the engine (makes it open the governor a little) with no lever movement it might be the valve adjustment.
Pressure testing it is in order. I hope this helps. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
