Let's make a summary of some of the info that has been posted:
1.) compression, check all cylinders. Should be within 10% +/- of each other
2.) Is the intake leaking anywhere.
3.) is there good gas flow TO the carb. Is the screen plugged where the fuel line goes?
4.) mag can only be adjusted about 10 degrees. It is either in time or 180 degrees out. battery ignition can be adjusted way more than a mag.
5.) valves sticking or out of adjustment.
6.) is the governor working correctly.
You problem sounds like fuel. but checking those other items certainly will not hurt, and will give you absolutely where you are with the key parts of the engine.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
