Posted by jdemaris on April 25, 2014 at 09:48:11 from (70.194.8.245):
In Reply to: B250 oils posted by bcdave on April 25, 2014 at 08:07:37:
Tractor Supply carries it. 90W for transmissions is the GL1 oil I'd use (if I wanted mineral oil). Non-detergent 30W motor oil for the hydraulics. I have to use pure mineral oil in the transmissions of my Oliver and Case crawlers because the wet brakes can't handle EP additives in GL5 oil. I doubt you need GL1 "mineral oil" in a B250 though. Only reason to feat it is if your system has a lot of yellow metal (brass, copper, or bronze) or wet-brakes. My B275s (got three of them) have had 90W GL5 in the transmissions for years and generic hydraulic oil in the hydraulic reservoir. Ford N series tractors also called for pure mineral oil in the transmissions. That's why Tractor Supply puts "Ford" on the label. I would not use 90W in the hydraulics though unless you live in a hot area. 90W mineral oil is actually 40W when rated for engine use. By engine ratings - 20W or 30W is much better for hydraulics. Any 20W or 30W non-detergent motor oil is fine. So is just about any oil sold as "hydraulic oil."
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
