Posted by The tractor vet on April 29, 2014 at 16:21:49 from (75.24.5.173):
In Reply to: SMTA hydraulic setup posted by Brady Miller on April 29, 2014 at 12:21:26:
1250 is what a good system will do and trying to push more you will most likely lean all about cam gear failure . You will be like the one guy around here that did away with the Hyd. unit under the fuel tank and made up a tank for the oil and ran everything from the pump to his valve set up . First time he use it when he went to lift the disc at the head land to turn he did not let off the handle of the valve fast enough and deadheaded the cylinder and before the relief valve opened to dump the pressure off his tractor just stopped dead. It would not restart and i get this call about his tractor died . So road call and start looking at his reenginering and had to look no further then the rotor , when you tried starting the tractor the rotor did not turn anymore . So a new set of cam gears and it was back running and i reset the regulator to 1250 and it was fine . On the OLD systems if what your trying to lift won't lift get a bigger cylinder or get a newer tractor with higher pressure hyd.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
