Re: Stuck hydraulic coupling in 7140 magnum
Posted by mkirsch on May 01, 2014 at 05:19:57 from (65.199.189.6):
In Reply to: Stuck hydraulic coupling in 7140 magnum posted by MN Mike on April 30, 2014 at 07:04:37:
He said that already disconnected the hose from the cylinder.
Whatever the problem is, isn't pressure related. The coupler is jammed, because of dirt or a defect... Don't know.
At this point, I think he's just going to have to figure out a way to apply more force to the coupler. Some sort of pry bar arrangement.
One thing I'd try, is get a thick washer that will fit over the threads of the hose, and install it between the hose and the coupler stuck in the tractor. The washer will give you something to pry against. Might want to use an old hose so you don't ruin the end on the implement hose. The coupler is probably a lost cause.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
