Re: 51 SUPER C DISTRIBUTOR
Posted by mkirsch on May 01, 2014 at 11:33:30 from (65.199.189.6):
In Reply to: 51 SUPER C DISTRIBUTOR posted by PETE CORMIER on May 01, 2014 at 07:36:22:
No need to look at the flywheel.
If you shine a light down into the #1 spark plug hole you can SEE the piston come up to TDC.
Just remove the plug, stick your thumb over the hole, rotate until air starts pushing out, then watch it come up on TDC.
These engines turn easy enough you can rotate them with the fan as long as the belt's somewhat tight.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
