Posted by Danby on May 05, 2014 at 22:10:45 from (97.126.77.106):
I'm having a heck of a time getting my 300u to fire up. I replaced the head gasket after finding water in the oil, and did serious clean-up, but not a rebuild, on the carb.
I've checked all the plugs with a spark tester, as well as outside the cylinder. The coil is brand new, from NAPA. I did a compression test and all 4 cylinders have good compression. First stroke hits 90 psi, which is 6.6 x 13.6. It tops at 120 psi, which I assume is okay.
That left me fuel and timing. The plugs are getting wetted with gas, so I'm pretty sure I'm getting fuel. I even tried a spray can of stating fluid, which I can reliably ignite in the carb by setting timing back far enough, but not in the cylinder.
No matter where I set the timing, I cannot get this thing to fire. Is there something else I'm missing? Spark heat? I've already burned up an old battery trying to start it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
