Yes if its a 40 model the suffix codes didn't start being used until serial number 18159 and higher. Never sure that was the first gasoline tractor sold though. IH did send a gasoline to test at Nebraska in 1939. Going by the tractor serial number tested it was probably a preproduction tractor.
Serial 15327 was built in May of 1940 and the suffix codes started on ones built in June of 1940.
There is a chance it came as a gasoline, although slight. Can't say it didn't come gasoline for sure though.
Only way I can think of at the moment to get a idea, is to see if a date code and casting number can be found on the cylinder head. If its a gasoline casting with a date code date before May 1940 it would a good indicator it came without the starting tank.
Did think of something else. Probably can get a idea if the head was changed before going to the trouble of looking for the casting number. If it has 7/16 diameter studs and nuts mounting the manifold to head instead of 3/8 it has a newer head.
Also the engine serial number is probably the same as the clutch housing serial number on that serial number range.
This post was edited by D Slater at 04:28:56 05/06/14.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
