The 656 does have two pumps mounted piggy back. There is a difference though from the older 560 for example. On the 560 the main pump feed the aux system and the smaller piggy back pump is strictly for the power steering.
On the 656 the larger main pump first goes to flow divider for steering and balance goes to aux valves. The smaller piggy pump is for hitch but if hitch is not raising the flow from hitch pump joins the flow from other pump to go to the aux valves. Separate relief valves for each system also. So, first thing to check is relief valve for aux valves located in the rear of aux valve block. If sounds like sucking air check return hose inside rear of tractor through 3rd arm link plate.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
