Posted by The tractor vet on May 11, 2014 at 12:37:52 from (75.24.5.173):
In Reply to: C263 to C291 ? posted by JT's RandR on May 11, 2014 at 09:30:08:
To make a C263 into a C291 the block has to be bored . and the special sleeve for this has to be used . I have done a bunch and the results are amazing . But i get carried away on the rebuilds . When i say rebuild i mean rebuild . Line bored (not Honed ) deck is trued up crank is done if needed rods done both ends, head total rebuild and cam rebuild and blue printed with new lifters , rockers reground , Distributor recurved as when you go to 291 the total advance timing needs to be layed back to 19 degree Before TDC at full throttle . The main fuel jet needs to be opened up just a whisker like about .0015 . And if ya really want to gain a few pony's then ya have everything weighed and balanced . Then when you start to put the engine together you hand fit each piston to the hole your going to put it in and give .004 skirt to wall clearance . Now the big thing here if you want it to live a long and happy life then you must FEED it the prime rib of gas and use nothing but 93 octane . Now as the reason to run the low ash oil , if ya don't they will plum eat exhaust valves . My two closest fiends run C291 706 and they get the bag run off of them on a full time working farm . The 706's are the go to tractors when the weather turns cold as they have the power and weight to do what is needed . Will they use gas ??yes so does your pick up pulling a trailer . How much it will use depends on what your doing . I can mow rake twice 28 acres on one tank of gas with a 9 foot haybine on some of the nastiest ground you will ever want to put a tractor on . I farmed for several years with a late model 706 with a C291 and pulled a 710 4x16 plow and a 370 13.5 foot disc and never thought that it used to much gas same as my Massey 300 Combine .
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
