Hi Matt, first check the fuel shut off rod is working properly and is connected to the lever on top of the fuel injection pump. Next check the fuel flow out of the fuel tank. One of the fuel filters may have a glass bowl on the bottom with a drain screw, this is to drain off any water that may have collected in the fuel. There is a hand pump on right side of engine just above oil filter, this can be used to prime and bleed the fuel system. There are two bleed screws on the injection pump, bleed the lower one first then the upper one. Open bleed screw and pump the hand pump until fuel comes out the bleed screw without air bubbles, close bleed screw and repeat for next bleed screw.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
