just from what you are saying about dirty gas is your problem. all it takes is a spec of dirt to flow into carb and you are in trouble. these carbs with the fuel pumps are more prone to problem. the fuel is pumped into carb under pressure and is always stirred up. excess fuel is returned to tank. soo... you have to start right at tank and make sure it is clean. make sure fuel pump works. check flow and pressure. a needle valve cannot be the problem,... its the stuff plugging it is the problem. take your tank to a rad shop and they will boil it out in caustic. you will never get it cleaned by flushing with gas or diesel. the rust flakes just keep falling of and go into the carb. good idea to put an inline filter before carb also. most of those sediment bowl screens got thrown out. and then once tank is cleaned, if required it can be sealed.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
