Engine surging on C301 in a 706
Posted by freddy on May 17, 2014 at 16:48:43 from (99.151.39.25):
Tractor is back together after engine change. Engine likes to surge back and forth from low rpm to high rpm. Changed governor but did not help. Governor arm is going back and forth with the loss and gain of rpm. Will settle down and run good at higher throttle setting if you calm the surging by holding the carb shaft. Seems to be loading up and then takes off then compensates for the rpm and backs off again,. Carb seem to be a problem. Idle screw can be screwed totally in and will still run. carb has been rebuilt with a kit. Carb is in great shape but there must be something wrong with it. Have any of you gentlemen out there seen this problem and how did you fix it?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
