Re: H connecting rod bolt lock tab
Posted by NNP on May 18, 2014 at 04:11:14 from (66.66.112.196):
In Reply to: H connecting rod bolt lock tab posted by bassmasta76 on May 16, 2014 at 12:43:56:
if this is a good running tractor with constant good oil pressure,
I'd just leave it be. Breaking or stripping a worn rod cap bolt to just change those clips will ruin your day.
With that said, when I buy a tractor, especially a Farmall where it is so easy.....and I have the oil pan off for cleanup....
dunno..can't resist I guess.
At a minimum, I'll put new rod bearings in (same size that are in there) Then plane the oil pump cover plate, and put a new gasket in it.
Peace of mind for under a hundred bucks.
(And every time, I didn't...I regretted it later)
old parts get labeled and saved. Got an engine right now that is not worth a single dime. But with my old 'not too bad' bearings and engine parts collection, it's going together with all used parts. Correct...no, will it run and be useable..yes
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
