Posted by 806jr on May 20, 2014 at 01:34:50 from (199.223.221.145):
In Reply to: 806 pto issue posted by Cornbower on May 19, 2014 at 22:09:16:
Check your splines on the IPTO shaft, this is the hollow shaft that has the smaller shaft sticking out of it, the splines will wear thin and then will start to bend over. Also check the splines inside clutch pressure plate that the IPTO shaft slides into, they might be worn down to. It could be something inside the pto also, sounds can travel to different areas threw the shaft that runs the pto.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
