Posted by wfd2 on May 21, 2014 at 19:01:40 from (72.104.71.144):
Four years later I'm having the same problem with my '47 H. Sure enough the battery cable stud was the culprit. But, in my case, it was shorting to ground.
Check to see if you have continuity between the battery cable stud and the case. If you do, the stud is cracked and shorted to ground inside the starter.
I took mine apart, straightened out the lug and soldered the connection. Starter works like a charm.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
