Sounds like failure of bearing in transmission or final drive. I drain each plug separate to see which compartment has the bulk of the filings. Any time you get metal on the screen that tells you the filter is plugged and oil is going through the bypass screen valve. There are four different plugs to drain. Pump won't put enough crap in filter to plug it as it will quit pumping altogether before that.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
