Like others have suggested, you need to determine the cause of the bleed down before you start spending money.
If it turns out to be the cylinder, a new OEM cylinder would cost several hundred dollars, if you could even get one. CaseIH does not list the cylinder as an available part, so you're out of luck.
A hydraulic shop should be able to replace seals and o-rings in your cylinder for a couple hundred at most.
It's a tie-rod type cylinder, so you could tear it down yourself, even.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
