I had a 45 H that had the "factory" 6 volt system. You will need the following:
1. What they call a third brush generator, with a cut out relay
(voltage regulator) mounted on top. Be sure you buy one that already has the original pulley & fan on it, & hopefully the original cut out relay as well. DELCO P/N 1101423
2. Bulb replacements for the head & work lights.
Westinghouse # RP-11
3. Large 00 (double ought) battery cables, ( or used welder cable) be sure to solder the connections, and use shrink wrap on the connections. The positive should be connected right at one of the starter mount bolts.
4. Buy the highest cranking amps 6 volt battery, I have had very good luck with the new Optima battery # 9010-044. They won't rot out your battery box either.
5. If your existing wiring harness has been butchered, I would think about either purchasing a replacement, or wiring it yourself.
I would purchase a complete used original one & rebuild it before you install it. Parts for any H are plentiful, they sold quite a few over the years.
This post was edited by rhtx55 at 12:46:16 06/01/14 2 times.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
