[quote="Janicholson"](reply to post at 18:32:16 06/03/14) [/quote
Thanks that makes sense for the pop. Did check spark at the plugs and it "seemed" OK but who knows. Dealing with alot of old wiring so I will check cranking voltage tomorrow after the battery charges.
Will do as follows if I read the above right: Disconnect the wire that runs from the - (negative) post of the coil to the distributor and ground it, then check cranking voltage at the + (positive) post of the coil.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
