This comes from the time we had to actually use the tractors to work. They do not like to sit up. They like to run and if they set up too long they get testy. Clean the points with a thin paper or dollar bill. Make sure the fuel is fresh. Do not hesitate to use a little starting fluid after a long period without running. Make sure there is no condensate in the carb. Do drain both the tank bowl and the carburetor bowl. If it starts to run rough drain the bowls again. I have had to do this several times while burning a couple of tanks of gasoline before it would start and run well. Once it clears out the old fuel and condensate it will run fine. If the problem does not come back then act as though it never happened. You might have had both a spark problem and a fuel problem or one or the other. If cranking it up and letting it run for a while solved the problem then get your plowing done.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
