Re: Bars leak stop leak update
Posted by Red Mercury on June 04, 2014 at 20:49:01 from (204.112.27.204):
In Reply to: Bars leak stop leak update posted by Patrick HMD on June 04, 2014 at 15:44:16:
Here is something to think about....
I had the same problem with a W-4 and a Super W-6 after I removed the water headers. They were seeping from a couple of places around the header. I don't like to use Bar's Leak or any other stop leak products for that matter. So after some thought I decided to run them with the leaks, knowing that there is a certain amount of debris in the cooling systems of all of these old tractors even though I removed as much rust and sediment as I could when the header was off. After a couple of weeks, they both stopped leaking and have never leaked since. I suspect that once the gasket got wet and then some debris from the cooling system made it's way into the leaks all was well.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
