Posted by mkirsch on June 05, 2014 at 05:10:59 from (65.199.189.6):
In Reply to: stalling 504 farmall posted by Larry Zuefle on June 03, 2014 at 16:46:00:
Unless you wrapped the fuel line several times around the manifold before you connected it to the carburetor, I highly doubt it's vapor lock.
Have you checked fuel flow? With the line disconnected from the carburetor, gas should flow full force out the line, not dribble, not trickle.
The overheating may be a another symptom of the actual problem. Burned valves will cause an engine to suddenly stop running inexplicably. I had a Cub Cadet once that would fire instantly and run fine, but after about 2 minutes, it would just stop running. It would start right back up and run a little more, then quit again. Over and over. Turned out to be a burned exhaust valve.
Burned valves seal well enough until they get warmed up a little, then they don't seal at all. No compression, no run...
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
