Pulling installing dry sleaves Farmall IH 400
Posted by husker44a on June 08, 2014 at 15:45:15 from (199.47.66.60):
A few weeks ago I posted about coolant in oil on a 400 Farmall. I removed oil pan and done a coolant pressure test. I wasn't seeing where the coolant was coming from until I rolled the engine over then coolant would leak around number three piston onto the shop floor. I knew at that point if coolant would leak past the rings with 20 lbs psi it needs a complete overhaul. Pulled head off and seen four cracks in the head and a bad headgasket. So, we're going to get a All States major inframe kit and a reman head. I was going to weld a bead down the inside of sleaves for removal but what about installing sleaves how do you guys do that ??? Thanks a lot !! Is there any thing else I NEED to know BEFORE installing the rods on NEW pistons ?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
