Distributor Insertion
Posted by PaulW_NJ on June 20, 2014 at 06:45:57 from (108.35.229.108):
Finally trying to restart my 240U after rebuilding the engine, and discovered last night I had apparently put the distributor in 180 degrees out of synch with the valves. So it was firing on the #1 cylinder exhaust stroke rather than the compression (explaining the backfires but no start). OK, so I realize I need to point the rotor to #1 wire position on the distributor cap, while the #1 piston is TDC on compression. But how do I know the correct position of the distributor housing itself? While the distributor was out, I replaced the points with a Petronix electonics ignition, so I can"t watch for points opening.
Would appreciate thoughts and recommendations.
Thanks
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
