Posted by rhtx55 on June 28, 2014 at 10:22:20 from (68.185.207.25):
In Reply to: 460 oil pressure posted by Matt1983 on June 27, 2014 at 14:59:27:
While you have the pan off plasti-gauge the rods & mains to check clearances to see if they are within specs. The only other place would be the cam bearings, if they weren't replaced this may be a contributor to low oil pressure at idle.
The next place would be the plate on the oil pump, perhaps too thick of a gasket causing excessive clearance between the housing & gears.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
