Hi as others have said heat, but if it was me I would heat them cherry red, then cool them slowly with cold water. Then try un doing them, going from side to side gently with the wrench to clear threads as they hopefully move . Never try moving them hot you will probably strip the threads off the stud/nut. The water will break the rust loose on cooling, lay off the impact also as you can't feel whats happening to the threads.
Looks to me like they are studs threaded in the manifold. if you break them off ,they may of heat hardened over years of use, cast manifolds can get hard to with the heat from the motor over time. Have had some here a good file won't touch . This might make getting them out or drilling and re threading pretty hard. Go careful with them, slow pace now is better than a huge headache later. Regards Robert
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
