Posted by pete 23 on June 30, 2014 at 20:06:16 from (173.87.0.139):
In Reply to: Farmall H Water Pump posted by Brandon K on June 30, 2014 at 18:01:36:
It is normal for coolant to be in that passage. Like I said, there are two bushings the impeller shaft rides on and there is a space between them. The packing that prevents leakage to the outside end of the shaft is behind that packing nut on front end. After you plug that hole the coolant will try to get past the next bushing and the packing. If it seeps a little tighten the packing nut some.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
