"I think next I'll do the "motor" test on the generator. From what I'm reading, if I can run the generator as a motor it should charge."
ACTUALLY, its my opinion that its ONLY if it passes BOTH Motor Tests (see my Troubleshooting Procedure below) it should charge. The first shows if the armature and brushes are good while the second shows the field windings condition.
"What about the cut-out relay? I see various posts about VR's, how does one go about testing the cut-out relay?"
If the cutout relay is working (a VR also has a cutout relay inside it remember) when the tractor isn't running there would be hot battery voltage on the BAT terminal but none on the GEN/ARM terminal (unless its stuck closed). Then once running iffffffffff the genny and all else is wired correct and working, the normally open relay closes so theres voltage on BOTH the BAT and GEN/ARM terminals, but once shut down the relay if working should open.
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
