Are you using OEM coils, or coils from an auto parts store?
If the tractor uses a ballast resistor, use a coil marked "for use with external resistor".
If the tractor does NOT have a ballast resistor, you need a "true" 12 Volt coil designed for such use. Contrary to what many guys believe, they do NOT have a resistor inside them, they are simply wound with more turns of wire.
The other issue COULD be if the tractor has a ballast resistor and it is nor properly connected into the primary ignition circuit.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
