H running rough
Posted by Peter Hoyt on July 09, 2014 at 20:43:04 from (67.241.76.247):
I did a valve job plus rings & rod bearings. compression 105 in all 4. oil pressure 75. water is getting into oil and cyl #1 so I suspect either cracked block or seeping around head bolt; does that make sense? no visible leaks of water or air around head gasket.
It runs rough at high idle under no load. all new ignition parts, now it runs better under load at low rpm when cold but gets worse when warms up. no power at high rpm despite choking and playing with carb adjustments. seems to be getting plenty of fuel. can make black smoke with choke
I plan to get a carb rebuild kit and try that but running worse when hot scares me along with water in oil.
Also I was wondering if I should pull the distributor and examine shaft. If worn could timing jump around?
If anyone has ideas or suggestion please reply or contact me at ph44@cornell.edu.
many thanks to all....
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
