I can not see a good reason for it not to lock in the shut off position unless the rod is totally out of adjustment. You do realize the lever does not lock in the engaged position, right. The lever just floats. I have seen some people adjust the linkage so lever locks when engaged and in that case the lever will be totally out of wack in the disengaged position. It should have about half inch or 5/8th inch of tension in shut off. In other words, you feel the internal brake compress the springs inside when the pawl is that far from the notch toward disengage. Also, nice snap when going over center to engage.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
