First and easiest place to look is in the oil filter. If you have a rod or main bearing failure you will find shavings of brass looking material in the base when you take filter off. That would indicate major problems. If you find nothing or possibly fine aluminum you may have a scored piston and that, although serious is not as bad. In any case you will need someone with some experience do the repair or at least guide you in doing it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
