Posted by Rock2000 on July 17, 2014 at 20:56:08 from (162.200.3.95):
For the front seal on an H motor, how are the felt and rubber seals situated? I have a rebuild video that shows the felt put in loose first, and then the rubber seal is driven on. But when I pried the old seals out, it seems like the felt was on the outside, and the felt and rubber seals were inside of a metal housing that was driven into the cover. What is the correct way to install the front seals?
Also, on the engine rear gaskets, there are two rubber plugs that are pushed into the blocks, and the rear plate goes aside the plugs. The plugs stick out a bit, and where they stick out is into the area where the oil pan gasket goes. Do I need to cut the plugs flush with the oil pan mating surface, or should I just close my eyes and install and torque down the oil pan and oil pan gasket?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
