706 pto seal fix
Posted by greenredilikethemall on July 22, 2014 at 06:45:17 from (184.61.91.221):
I posted a couple weeks ago about changing the seal on a 1000rpm pto and was advised I must get the manual and have a helper. I did get a power train maanual and its ok. I took the whole PTO unit out and got the clutch and all out and split. I even pulled the shaft and changed the seal. Put the shaft back through the cover and having a heck of a time putting the snap ring back in. I'm talking about the one that holds the bearing pressed to the shaft into the cover. I attempted many times last night with a ring compresser. What a task. Have to finish it all today and drain all the oil and get this beast back together. The gears and shafts look great. looks like no wear at all.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
