First thing, make sure there's supposed to be a gasket. AFAIK those valves are only sealed with Orings, and a gasket will spread the metal parts too far apart and weaken the seal.
That said, I'd also look for blockages in the system downstream that are preventing the oil from returning to the reservoir and causing the pressure to build up.
From the way it sounds the relief valve is not working and if you put it together so the gasket can't blow, something else will blow. Probably, something expensive and/or no longer available as a replacement part.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
