How much have you run it since you did the tune up? These old engines tend to be a little cranky with old gasoline and when not run. Sitting up tends to make them run rough . . . for a while. Hook a load to it and go to work. Every time it starts running rough stop and drain the carb, blow out the fuel line and clean the bowl under the tank. It usually takes about a tank of gasoline to get it going right. (This the way I had to do it every spring back in the day). BTW if you have a rubber hose instead of the steel fuel line that was stock that could be an issue. Rubber fuel lines seem to have loops and will drop below the carb. Air bubbles can get trapped in the loop and cause the engine to run rough even with a clear carb and good fuel.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
