Pull the cotter key out of the pin holding the finger - then you can drive the holding-pin out. Then the screw-unit will drop out... it's a tapered unit.
He recommends taking your entire clutch apart and cleaning and lubricating everything.
Once it's all loosened up... then you put the screw-unit back in and do the measuring to set the fingers evenly. At this point, with everything being loose/oiled - you can just turn that adjustment screw with a regular flathead screwdriver.
He said don't put your cotter key back in right after you get the fingers evenly set. NEXT take the screw-unit back out and put it in a vice being careful NOT to turn it (so you don't change the setting). Then tighten down the locking nut to the edge of the screw-unit. Then you can reassemble it.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
