Feel the coil when it stumbles. If it is way hot, the issue might be that it is a 12v coil for use with a ballast resistor (which means it is really a 6v coil). If given 12v it can heat and break dowm, causing misfire. If the coil is warm and not way hot, My guess is fuel related. Put a can under the carb, and drain fuel for at least 2 minutes. If the flow slows down you could be having a blockage at the tank to sediment bowl connection, r in the screen at the carb fitting. The fuel cap has one or two vent holes in the top. Make sure the vents are open. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
