Hi as Jim said could be PTO dive splines on pressure plate. I assume you checked transmission fluid level. You can remove inspection plate from bottom of clutch housing and look at PTO drive shaft that is outer shaft that is splined and goes into pressure plate splines. You can mark the PTO shaft with a bright magic marker, then start engine and look to see if PTO shaft is turning at engine speed. If PTO shaft is turning, then check hydraulic filter but it should bypass if filter is clogged. Next would be hydraulic pump problem or MCV valve problems like stuck relief valve or blown O-rings.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
