Lift the front end with the loader or carefully with jack & stands. Then, with the tires just an inch or less from the ground, grease the pivots on each side(steering knuckles). If it steers easily with no weight on the front end after greasing, then I would look into the steering box.
Bushings & the thrust bearings should still be available, as well as new tie rod ends. If you go to rebuild the steering box some wear parts are available & some will need the assistance of a good machinist.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
