Posted by SDE on August 17, 2014 at 16:31:16 from (174.124.63.138):
I assume that to correct this problem, I will need to pull the head, pull out the piston and remove the sleeve. If the bore in the block is ok, then what do I do? Is the sleeve suppose to be a tight fit? If it is too loose, is that why the coolant is getting in the oil? If I get it fitted properly will the leaking stop? I don't think it is a head gasket problem, because I have not lost much coolant and it has not been over heating. Thank you Steve
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
