Re: super a oil pressure
Posted by NNP on August 17, 2014 at 20:55:48 from (66.66.112.196):
In Reply to: super a oil pressure posted by henhawk1969 on August 17, 2014 at 13:08:33:
I'm with eltoro, no more running til you find the problem, especially with an engine that has been sitting.
Get a hand crank, take the plugs out, take the oil pressure gauge right off. Don't start it again until you can get oil puking out the gauge hole by hand cranking.
I'd just pull the pan, probably needs cleaning anyway.
possible causes with pan off,
El Toro's relief tip
oil pump bottom plate gasket blown out completely.
completely plugged screen.
intake pipe broken or detached.
and not likely, but I just had one.....oil pump or cam oil pump drive gear teeth sheared off. (mine was the cam gear teeth sheared off)
Pulling the oil pump and after repairs, sticking it in a pan of oil and turning the gear...ok it works.
on to other places, now I KNOW the pump works.
This post was edited by NNP at 21:02:23 08/17/14.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
