It should unless the valve is only doing it part of the time. Like say it is sticking part of the time, but only at a normal running RPM. A situation like that would perhaps give you a normal compression test reading. If a low compression test, put a squirt of oil in the plug hole and then re-do test. If the result is a normal reading after being low, it is a problem with the rings. If it is low after being low it is a problem with valves most likely, but a chance of cracked head or bad head gasket.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
