Hand throttle is working the external lever on the engine side of the governor? Throttle tube shaft is correct in notch? Pin good in front of throttle tube shaft? Vertical linkage rod from throttle tube shaft down good? If all above okay, remove the side cover on the governor. See if the spring is pushing the rocker lever to rear of tractor when hand throttle is set to idle. Also look for stuck or damaged weights on the horizontal shaft or the bearing and slide damaged or stuck that slides on shaft to let weights close. If the carburetor throttle shaft is free to move without any governor linkage restricting it, as air pulls through the throttle plate it would keep moving it open.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
