Posted by wayne in mn on August 25, 2014 at 18:34:15 from (71.8.150.168):
In Reply to: h and m brakes posted by dewy on August 25, 2014 at 18:19:27:
Transmission may be in 2 gears at once. Push in the clutch & try to move the tractor. If brakes are stuck, disconnect the pedal & remove the screws holding the brake cover. Pry the cover off. You may have to take the brake lever off first; loosen the clamp bolt and split the clamp with a small chisel. Use a modified diagonal cutter(grind the flat side so it comes to a sharp point at the cutting edge) to remove the 1/2 moon key and then the cover should come off.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
