The type of drive your starter uses depend on a fast start of armature rotation to get the drive to engage. It has an inertia type drive with a helix spline to move the drive into position in the ring gear. The armature has to start very quickly so the drive will slide down the helix and engage the ring gear before it starts to turn with the armature. If the armature starts too slowly or the helix is sticky the drive will start to spin before engaging the ring gear.Running at 12 volts actually makes this type of starter engage better. The down side of the more rapid rotation is that it puts more stress on the spring in the drive when it has to start to turn the engine. On the other hand the same drive is used on an M and many of them have been used for years with 12 volts and have not and broken springs. It is highly unlikely you will ever see it happen on a 100.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
