Caps are the most common cooling system failure. Look closely, there s a small mushroom like disk (atmospheric valve) on the bottom center, it should be held closed by a very light spring. Its rubber should be in good condition, as should the rubber that seals against the neck flange. The tension spring that applies pressure is also a failure point in that it can rust or corrode away. The atmospheric valve is to allow the cooling system to draw in air as it cools off, this prevents collapsed hoses or components like top tanks. New caps are cheap. Jim
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
