A 102 should have battery ignition, battery, points and coil (at least mine does). Are points gapped? take off the cover and turn it over and see if they're opening and closing. While cranking spray gasoline or starting fluid into and see if it tries to run, if not trouble shoot your fuel system. Check for spark at the plug (if nothing else clamp the plug to the lifting lug hook up the wire and crank it over, should have a nice blue spark, while doing this you can also see if it's got compression (is it pumping air out the plug hole?)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
